Re: L/U seal's
hello<br /> be aware of the saltwater use foot notes
<br />if there is no corrosion and we dont include R+R the case 2.7 is doable. if you add in 20 min of oxy acetylene and 45 min for cleaning and inspecting corrosion of the housing and 15 min to drill out the bearing carrier nut it may take a bit longer. in my area its about a 5 hour ordeal to strip it, clean the housing and reassemble it. I usually remove the driveshaft as well so toss in a pinion nut. usually I replace the lower base and upper pump housing assy. at 75 per hour if I spend 15 min messing with the old base and seals you have paid most the cost of a new one.<br />reassembling is the quick part
<br /> dissasembly ,cleaning and inspection is the long part
. so somewhere between 3 and 5 hours is normal.add another hundred for parts and your close
