diggerdan17
- Joined
- Apr 11, 2003
- 148
New to me 1998 bayliner capri 1850 SS with the mercruiser 4.3 190 HP V6
engine serial # 0L011173
drive serial # QL127614
Took it out to the lake today (ice finally came off!) and it seemed slightly under power when trying to plane . Then when up on plane it leveled out at 4200 rpm and about 40 MPH ( GPS) went through some rough water and it came to life and hit 4900 rpm (trimmed out) and was doing 47 MPH. Prop is 4 blade 22 pitch aluminum. Played around with full stop to wide open throttle for a bit and some times it would plane fast and hit 47 mph and other times it seemed gutless and only hit 40 mph.
I do have a spare fuel/ water separator filter that I can put on (which I will, and I'll dump contents into clear jar and let sit to check for water). Whats my next step to check after filter? Boat idles very nice at 600 rpm and shifts beautifully, no water in oil and it holds steady at 175 for temp , oil pressure is 30 psi at idle and 60-70 at WOT.
I am going to figure this out and will post back with the resolution so any body searching for similar issues will know what solved this.
Thanks
Digger
Thanks
Digger
