Laguna Bay Hot Tub not heating
massimofinance
I noticed my hot tub heater stopped working. I checked the circuit board and the connection looks fine. Can someone help me diagnose this? I get an error code: ECP which means "Water Flow Error." The advice is to "remove debris. Make sure the slice valves are locked in the "UP" position. Clean or replace the filter." I did all that and nothing. Thanks!
Also to test you can short across the switch with a jumper to see if that clears the issue
