I was given this boat so how this happened, I don't know. The dent in the picture was repaired with some type of epoxy, etc. Obviously, the boat was taking on water after whoever messed up. Anyways, the epoxy was dripping as it hardened, leaving little stalagmites everywhere. When I picked up the boat, I had to put it in the water and use a trolling motor to get around to the neighborhood boat ramp (I havent been able to run it with an outboard yet, so I don't if the steering is ok). The boat showed no leaks...the trip took about 30 mins. A friend said he would bondo over it, i thought about a piece of aluminum and trying to bend/shape it and rivet it into place(look close to original), or what about getting a tig welder to cut out the area and weld new. I don't know where to start...what would you do?
