Re: Larson 174 SEI
Hello folks I am new to this forum and I have never owned a boat. However there is one right down the street from me it is a Larson 174 SEI it has a johnson motor out back the owner says the motor starts fine. What should I look for when purchasing a boat ?? This guy wants the boat gone quickly the boat is a 1994 model can someone tell me anything about Larson Boats ? My wife wants it pretty bad he is asking 1500 and comes with a set of water ski. Thanks for any input !!!!
Forget the Water Skis. Offer 750 if it has a trailer, you can pay 1000 or 1200 then. Do you know this "neighbor" well?
Check for:
- Soft floor
- Engine:
- Starts up promptly when cold
- Warms up but does not overheat
- Sounds and runs smoothly in idle
- Accelerates quickly with no noticeable "hole"
- Turns and runs smooth while turning tight (left and right)
- Trim working
- Gauges working, Oil pressure, Temp, Speed, RPM, etc..
- Speed at WOT, engine still not overheating
- Come off WOT, engine still not overheating
- Starts up promptly when warm
- When finished check for water anywhere in boat
- When finished check oil, if milky - walk away
- Mold, Smelly stuff especially when wet
- Water anywhere in the boat and smelly ski locker
- Holes in the hull, scrapes in the gel coat, nicks etc..
- Patched areas any evidence of "prior art"
Without a water test the boat is worth the trailer minus the cost to get rid of the boat.
Good luck, post some pics if you can
Roland
