Hi everyone. New owner of a 2012 Larson LX850. The boat sat dry for a year, we had it serviced and wrapped for the winter. This spring, we made sure all valves were closed, drain plug tight, etc. and put it in the water. The boat is taking on water while docked. It sat for 2 days, and when we ran the bilge pump, it pumped a full 1" thick stream of water for 13 seconds. Not quite sure how much water that is... half gallon, maybe more? I'm assuming this isn't the norm.
I can't seem to determine if the bilge pump is automatic? Regardless I need to get the leak found and fixed, but I'd really like to know if the bilge pump has a float that automatically turns it on once the level is high. The boat is 3 hrs away up north, so not exactly easy to pop in and run the bilge pump ever couple of days.
Any ideas where to look for the leak? Valves, drain, bellows?
Thanks,
Dan
Thanks,
Dan
