laser2
mkfs9
owned for 12 years perfect.had it refinished, only miner chips on leading edge.new hub.now it does not even get me on the plane.had it checked by the repairer and they are baffled by the problem.alfa 1/mercruisre v6/searay 18 ft.
Don S
Re: laser2
Maybe it's the engine, and not the prop. What are the symptoms?
mkfs9
Re: laser2
engine perfect just serviced.alloy prop works fine same pitch 21".prop just seems to cavitate
novicetech
Re: laser2
Make a continious mark across the hub and prop with something that wont wash off and try to run it again if the hub is acting up the marks will not line up.
novicetech
Re: laser2
Just because the hub is new, dont mean it is not the problem, they take alot of pressure to press in and could have cracked your prop or even put the wrong one in, mistakes do happen, and I am only trying to find your most logical, least expensive and simplest solution to your problem.<br />Since you say it runs good with the other prop.
mkfs9
Re: laser2
my new hub is not the older style press in type.it is the newer type with a removable splined insert.these are much easier to replace.<br />thanx for your help.
