Ok.
1997 Merc 3.0. Only reaches about 3500rpm at WOT. Even has a prop that should be over revving the boat. I have been through everything in the WOT RPM list.
New longblock. (old engine had sub 100 compression numbers)
New fuel pump.
Rebuild carb. Even tried a new one, same results.
Cleaned and inspected fuel system tank to carb inlet.
Fuel vacuum / pressure test.
Tried two different ignitions, same results.
Verified timing multiple times.
Verified voltages under load for proper ignition feed.
Verified tach with shop tach.
In fact, the only thing not replaced at least once on this engine is the intake/exhaust manifold. Is it possible that this WOT issue is caused by some defect in the manifold itself?
It is worth mentioning that the original engine had trouble reaching WOT RPM. And when the compression read low, I figured for sure this was what was causing it. It was actually a jasper reman and supposedly replaced an original merc. So this is the boats 3rd motor (wonder if the manifold has had issues since the original motor went... possible due to overheat?)
Spoke with a mechanic friend of mine and he keeps mentioning the manifold. It's a long shot, but honestly, its the only part left that hasn't been replaced.
Any takers?
New fuel pump.
Any takers?
