Re: Late 50's Elgin w/ optional Hp 5,7.5, or 12
Hi Ump,<br /> Your motor is water-cooled, so I'd look into finding an impeller for it. If you get a friendly counterman, you might be able to bring your old one in and match it up, or at least get something close that can be doctored to fit.<br /> As for your running issue, first, make sure the motor is in te 12hp setting, or the governor will prevent it from throttling up all the way. Make sure the key on the front is actually working the linkage to give you the 12hp.<br /> Also, make sure you're running on both cylinders. Pull the plug wires off one at a time to see if there's a difference in performance. If the motor keeps running and doesn't miss a beat, then the one you pulled is the dead one. If it stalls immediately, then that's the good one.<br /> Run a compression check, too.<br />- Scott
