Re: late 60's Lamar 15 ft fiberglass boat built at Central Boat Works in Texas
LOL :O) the "RARE" part I was referring to had nothing to do with value, it had to do with not being able to find any info. about it or pictures of them. I don't figure the hull is worth much other than parting out the outboard controls and other rigging. The motor turns over fine with the pull rope (haven't tried hooking up a battery for the starter) There is a nice "thump" of compression and a fair amount of resistance as the pistons come up, so I feel the compression will be fine. I haven't done anything more than clean the trash out of it and hose it down to get the loose stuff off. I'm thinking of just selling it as is and maybe making a few dollars for my efforts at this point. I really don't like the styling of the boat, but someone possibly does. I will tell you that the hull is solid and the hand crafted trailer is as fine as I have ever seen (really it is) The original owner spent countless hours making this trailer custom to this boat. It's a tilt trailer, the attention to detail is incredible. Little things like copper tubing with flairs on each end running the length of the trailer to run the wiring through, the bunks are a perfect match to the shape of the hull and in between the keel bunks he installed rollers that lay down out of the way until you are ready to load and you pull a leaver (has a lock bar that holds it in place while the rollers are up) the rollers rise up and your boat glides along these rollers. Once in place, you lower the rollers and the boat settles down in the solid bunks. There is absolutely no wear on the hull from loading and unloading. Very cool and quality built trailer. I hate to part it out because everything is intact at this point (other than the seats) and it would make someone a nice project that needs one, although all it really needs is a good cleaning and some seats for the hull to be ready to play. The motor will surely need a tune up and the electrical needs to be repaired so the starter will engage. I really don't need another project myself, I just hated to see it just sit there for another eight years (she got the boat eight years ago when her father died and moved it out if his shed to her place and put plastic over it, a few years ago the plastic started coming apart) and go completely to waste. Could be a nice little boat again.
