salvageyard saviour
- Joined
- Oct 28, 2018
- 164
I'm trying to fix-up a late 70s 5.7 GM. Casting numbers show it as "78"
It came out of a 1972 24ft Starfire hardtop with the original OMC electric shift.
My confusion is about the manifolds, carb and distributor.
Question 1: How do I know what parts I have? 72 or 78 ? does it matter?
The intake is stock GM cast and seems to have white paint under the black someone sprayed it with. Carb is a GM QuadraJet with non electric choke. Point distributor.
Question 2: When putting the intake back on, Do I use the seals on the front and back ridges or just beads of sealer?
Do I use the little plates to block the exhaust crossover?
It had none of this when I took it apart.
Question 3: I have a complete "85" with lots of extra parts. GM and Edelbrock manifolds and carbs. Can I use anything from this newer motor such as heads, crank, cam, intake or distributor? Swap entire engine?
The "85" is a crate engine. I have no idea where it's been. I got it with burned main & rod bearings from bad oil pump.
The "78" I assume is a marine app because of the white paint under the black. I got it with a blown head gasket and 2 froze pistons (#1 & #3) from the water in them from the blown gasket.
