Hello all,
I have aquired a 14' runabout with an older 40hp on it. The engine has not run in a few years. The problem i have is i don't have a key for the ignition switch, so when i brought her home, i tried to get it started.
Due to not having a key, i applied 12vdc directly to the starter motor. Sure enough the starter popped up and turned her over. Would not fire up however. Fuel seems to be getting past the filter.
I pulled the spark plugs and did not see spark, but they were dark and wet so it appears there is fuel there.
My real question is, by bypassing the key switch, will this still allow the motor to fire? i understand there are two wires from under the flywheel which run to the key switch and act as a kill switch?
Tomorrow i will go back and pull the flywheel and clean up the points and check for spark again, but i just want to be sure im not chasing around for no reason if it has to do with the switch.
Thanks!
Kevin
Thanks!
Kevin
