This is an update to another thread I had going but seems like it went missing. My problem (I thought) was that I had no spark at cranking speed on at least one cylinder. This is from what I remember from last year. I did a spark test on all cylinders one at a time and started the motor each time on the other 3 cylinders. Each spark test was hot and consistent at 1/2" gap. I also used a timing light and each wire produced a consistent light pulse. The engine ran as good as expected on 3 cylinders with the wire off the test cylinder and no difference based on which 3 were hitting. Overall, the motor runs good. I'll watch it when I get it on the lake after it's run a while and keep the tester handy. It is the '77 model with one ignition module and 4 coils. Thanks for the input from my previous thread.
It seems like the folks running the site are getting the bugs worked out because it seems to be running better. Many thanks to the people that put this site up and to the many folks and experts that help out answering these threads.
Mark
Mark
