Re: Late 80's suzuki dt-150 pros-cons
I have a 87 DT 150 SS. I've had a few issues but nothing major, other than when I first got it. My low oil warning module was bad and wasn't available, but was told that all I needed to do was disconnect wiring harness from it to CDI box. It does run strong. As with any motor, they need regular maintenance. I keep a check on spark plugs for any indication of problems. And I did discover after one outing that my #5 cyl coil pack was breaking down, but once I replaced it, no problem. At 20 plus years old, its just a simple matter of keeping an eye on it. It pushes my ProCraft 20' around our lake easy enough. The 2 plug per cyl is supposed to be stronger than one without 2 plugs, but I don't have any experience to verify that.
