Laying tape
breton26
I know this has probably been covered in the past but I want to be sure i understand how to do it. I am reattaching my floor to hull with fiberglass tape. I have the materials so what is the process? I planned on fillet, then epoxy, then tape, then epoxy then more epoxy. Can someone please go into detail for me as I have never dealt with laying fiberglass or epoxy before. Thanks a million, Chris
Re: Laying tape
I like to put down a Soaking coat of resin 1st,.. Then the fillet, resin, tape,+ more resin.......<br /><br />It's My thought that the fillet putty is less likely to become resin starved, if the substrate already has a Soaking coat...........<br /><br />Small batches on small areas til you get the rhythm................
Re: Laying tape
Cabosil,+ Microballons,... to a Peanutbutter Mix.......<br />Chopped Glass if it's a Big Fill.....
breton26
Re: Laying tape
What is the best way to apply the epoxy? Brush, foam brush, roller, spatula??
Re: Laying tape
All of the Above..........
Re: Laying tape
Originally posted by cc lancer:<br /> You can use a "Bondo" spreader ;)
:D :D How ya doing Bennie......<br /><br />I found your email when I got home from Maine the second time......... :rolleyes: <br /><br />I've been giving it some thought,..... I'll get back to ya........
Realgun
Re: Laying tape
Here what I did. I mixed the epoxy and milled glaas no cabosil or anything else as All I wanted was strength. It was like peanut butter and I just used a plastic putty knife ie bondo spreader. :) I smothed this on eith side of the gap where the floor and hull met. The nex day I used a brush and just the epoxy mixed nothing else then layed the tape into the epoxy. I then used a roller to push the fabric into the epoxy. worked pretty well. The roller is an epoxy roller designed to do this. Then the next day I got the wider tape painted the epoxy on and layed the tape in and rolled that. Then I filled the weave the next day. The thiner you get the epoxy the better the strength is in the cloth not the binder. :)
