Lead Fuel Additives
SwampThing
Did a search and didn't come up with any discussions on lead fuel additives.
I'm sure you've had to of had this one before.
I'm curious about the use / need for lead fuel additives for mid 80's engines and prior. The lead in leaded gasolines was originally used for valve seat lubrication. So my question is; are lead additive necessary or should I be adding it to my fuel mixtures?
I have 3 older outboards - a 1986 125hp Force which says it can use leaded or unleaded fuel. And a 1961 Johnson 75hp and a Ted Williams 4.5 hp from the 70's. Not sure of exact year, guess I should double check it.
I wondering if I should be using the lead additive. Is it "Needed"? Am I doing harm to the motors by using it or would I be doing harm to the motors by not using it. The Force literature is the only place where I've found any mention of lead verses unleaded fuels. But it only states that leaded should be my first option unless it's unavailable.
Is there a definitive answer on this topic?
roscoe
Re: Lead Fuel Additives
A waste of time and money to add lead or lead substitute.
Put your money into a good quality TC-W3 rated 2 cycle oil instead.
And yes, this has been discussed several times before, but the search engine is real lousy.
gss036
The lead additives were brought to market for older car/truck engines when unleaded gas was the only thing available. The older engines required lead as a valve lube, they have long since redesigned the engines and no longer required. I still have about 8 oz left on my shelf for an old 1976 Dodge engine.
As stated above you are wasting your money at this point of modern engines. Running a 2 stroke, buy the best TCW3 oil that you can afford and you will get longer life from your engines.
Paul Moir
Actually, the lead (TEL, tetra-ethyl-lead) additives will leave deposts in your engine which will harm it. No 2 stroke ever needed or wanted it. In fact, according to the manual on old outboards, you were to use fuel that didn't contain it if available. I have no idea why FORCE would recommend it.
TEL's primary function was as an anti-knock agent (aka octane booster). It's lubricating properties were coincedental.
JB
What Paul said, better than I could have said it.
D
DJ
Guest
Lead was strictly a combustion chamber lubricant (valves, etc.) for four cycle engines.
Lead is a complete waste of time in two strokes, along with other additives.
A good 87 octane fuel with TCW-3 oil is all you need.
Your pre '63' engines are 24:1, post '63' are 50:1.
Mdude
I was thinking that lead was originally used as a flame inhibitor as a cheap way of boosting octane. ....or at least by slowing down the flame travel, an engine could run higher compression. The valve seat lube thing was a side benefit that engine manufacturers took advantage of to cheapen their valve guides and seats. At least that's what I seemed to have dusted off in the cobweb infested part of my mind that hasn't been touched in years. So I can't remember where I got that.
kenmyfam
The valves and valve guides have to be much better heat treated (hardened and tempered)) with no lead fuel.
kenmyfam
That is with 4 strokes only of course. No problems with 2 strokes due to lack of valves and guides !!
Scaaty
TEL had 2 needed properties in older motors WITH VALVES...reduction in detonation (I don't know how this happened, and know none of the effects on 2 strokes), but was needed as a cushion for the exhaust valve which some older motors had the seat cut right into the cast iron head (old Harley Sporster motors did this....not sure on old car heads, as I wrenched 2 wheel stuff). It was this cushioning effect that kept the valve from beating the hell out of the seat. Early 70's started a ban on it and they started using hardened valve seat inserts.
