So after some reading, the lead shot is used on these carbs to block/cover drill or casing holes. Is it possible for one of these to leak air? Just curious. And what would work as a sealer if one was leaking or suspect of leaking? Thanks
I have had my carbs LEAKING gas out of those spots since I got the motor....my carbs are plastic and it looks like the opening is plugged with a brass ball....I have tried to seal it with instant glue and paper , and it worked to some degree....
it didnt leak much, so i doubt that air going the other way could be any issue at all..
just that i have gas inside the cowling....which i dont like!
