Hey guys, I found lots of help on here in the past amd hoping for a little more...
so.i remodeled my 88 bayliner and put it on the water yesterday. After working on the motor, tilt/trim, trolling motor and putting all new wood and carpet thru out the boat we took it out for 2 hours. It did good other than an idle issue which I put in a different post and a small leak coming from under the tilt/trim. So when I fixed the tilt/trim i accidentally switched the toggle so when i thought I was going up it was going down.. before I realized it, it had pulled the quaking off the side of the tilt/trim and pulled the bottom away from the transom and inch or so.
now there are 2 holes where maybe the old set up was thats why it was quaked. U can see from the pictures. The left hole just below the one with the bolt where the tilt/trim is mounted is where the leak was.
how can I fix this? Can I just recauck the tilt/trim? Please any help would be great thanks
