leak L/U to boat transom
trent_tweeter
Tried to remove L/U omc cobra. It only came out 1.5 inches, so I put it back together. Now it leaks when in water. What might have I done to cause this?
Re: leak L/U to boat transom
Ayuh,.... Ruined the gasket,..??
Not enough Info to say, really...
trent_tweeter
So if gasket is the issue, what to do? remove L/U and inspect it, replace or use some kind of gasket cement or liquid gasket assuming I can get the L/U off or pulled back enough to service the gasket?
Ayuh,... Are you talkin' 'bout pulling the Drive, or the lower unit off the upper unit,..??
The Outdrive is both the Upper unit, 'n the Lower unit....
RIDEPATE
You could have torn the drive bellows or pulled it loose.. It's tight fit between it and the U-Joints.
