C17LoadSmasher
- Joined
- Nov 24, 2001
- 152
Okay, all is well. Noise is gone. Well, nearly all is well. It seems there is a leak from the seam between the lower unit and the upper unit (whatever you wanna call it
). Anyways, I went to go and drop the LU to see if there was a misplaced gasket, but in doing so, I realized that the 4 large bolts were a little loose, so I called the Mercruiser dealer and he said to try just tightening them, it might seat the gasket better. Well, I did so, and in running the engine you can see water seeping out of the seam. Any ideas? I think I am going to have to drop the LU and check on the seals for the water pump, and the little o-ring for the oil passageway. If it's just a little water leakage, is it something to just let it slide? Just curiouse.... Any other ideas would be most appreciated!
