Re: Leaking 1993 Lowe 2200 Deckboat
That sounds like an awful lot of water for just a few leaky rivets? Are you sure you don't have another leak? Maybe a bad drain plug or something?
How about an automatic bilge pump? My Starcraft had a crack between two rivets and several that were pretty loose and it didn't leak enough to raise my concern. It would take on about a gallon at best in a day or two in the water.
I welded the crack and tightened all the loose rivets and coated the inner hull with Gluvit and it's bone dry now.
I'd take a real close look at other points that can leak, I had a drain plug years ago that drove me crazy, I was chasing a pretty bad leak and was having no luck, then I accidentally used an old drain plug and it didn't take on any water that day. I had told a friend to put the plug in while I readied the rest of the boat for launch and he used my old spare the was laying in the back instead of the newer one I had bought to replace it with. The drain plug was leaking through the center, even though it was tight in the hole, it wasn't sealed at the through bolt.
Deck seams are also a common place for leaks, but not as likely if the boat is just sitting.
If that boat is foam filled, you may also have a problem dealing with water logged foam now that it's been nearly submerged.
