Leaking Alpha 1 Gen II
JStutz
Went to pick up the boat from storage yesterday. This is my second season with the boat and had decided to wintrerize it myself with the knowlege I had gained from this site. Even though I thought I did everthing right I was a little nervous about what I would find.<br /><br />After arriving at the storage buiding I noticed a spot of gear oil under the lower unit and oil seeping out of two little holes on both sides of the lower unit. I never noticed these holes before. After hauling the boat home I hooked up the muffs, crossed my fingers, and turned the key. The engine started up quickly and ran great. No leaks from the engine anyway!<br /><br />I changed the lower unit oil before storage last year. The old fluid looked good. I have searched this site and found that I problably have some bad seals. I have never ventured into the lower unit so I plan to take the boat to a reputable boat shop on Monday. I guess my ultimate question is, What do you think caused it to go bad? I Guess it has to be related to the cold but what could I have done diffrent? The irony for me is I was so worried I would have a cracked block, never thought of a leaking lower unit! It's always something!<br /><br />Thanks,<br /><br />Jeff Stutz
Re: Leaking Alpha 1 Gen II
It could be the Shiftshaft Seal,... Or the Waterpump Seal.....A Pressure Test will show Which is leaking......<br />If it's Leaking,.. Anywhere,..... I send Mine out for a Full Reseal,+ Inspection...........<br /><br />There Isn't Always a Cause,...Sometimes,.. It's Just Time.....
JStutz
Thanks for the quick reply and the reponse. I have been beating myself up all night trying the think of what I forgot to do last season. Not saying I didn't screw it up, but I will tell my wife it was old age! :p
DHPMARINE
Jeff,was the gearcase oil level full?<br />If you fogged the engine thru the carb,that could be what you are seeing.The exhaust/water mixture drains out of the holes you mention.If the gearcase is full,it's not leaking.<br /><br />DHP
JStutz
I checked the level last night and it is low. I just looked outside a minute ago and have a nice spot of oil in the drive way. You would think I owned a Harley! <br /><br />Thanks for the help!<br /><br />Jeff
