tompowers85
- Joined
- Nov 28, 2004
- 125
I have posted on here a few times. My carbs keep leaking. I have rebuilt and replaced almost everything in them. I replaced the needle valves twice. I replaced all of the fuel hose and found a broken hose clamp letting air in the lines. I have also replaced the fuel pump and everything in the lines from the tank up. When i prime the bulb the carbs start dripping and the bulb never gets real firm, and the more i prime the more they leak. Should i keep dropping the floats down? The carbs have gotten a little better, they were spraying gas out before i found the leaking clamp. I have already adjusted the floats to stop 3/16" earlier then the book says.I also cannot get the engine to run faster than about 5-10 mph. I refuse to go back out until i get the lines tight and i get more power when a load is put on the engine. Will the carbs flooding really bad make the engine slow down alot when i give it the gas. My compression is between 125psi and 135 on all four. Thanks
