scoutabout
- Joined
- Oct 14, 2006
- 1,568
Our fridge is a no frills GE unit -- probably of early 1990s vintage (came with the early 1990s vintage house...).
Anyway, last coupla weeks we've come down in the morning to find a great bloodly puddle on the kitchen floor under the door. My first thought was the door seal is going (and it is, somewhat) which was letting warm air in, which was condensing on the bottom side of the freezer, creating water which in turn ran down the inside of the fridge and out the aging seal.
Then I remembered reading something about how auto defrosting fridges actually have a heating element that turns on periodically, thaws built up ice and drains the water into the back somewhere.
Anyway, I can see a drain tube inside the fridge running from the freezer down to a little funnel kind of thing which heads out the rear of the fridge. Thinking this might be clogged I gently ran some wire in there but felt no obstructions.
Can anyone narrow this down for me? I was figuring more on the clogged drain side as the flooding and leaking happens only every 24 hours or so versus what I'd assume would be constant leaking if the door seal was no good.
(whew -- that's the most I ever thought I'd be typing about fridges in one lifetime....
