Re: Leaking Fuel When Tilted
It is not unusual to have a small amount of gas exit the carbs when tilted, esp on the older engines. Your airbox should have a good/new gasket on it, and it will trap the excess gas in the bottom of the airbox-instead of it leaking into the lower cowling. The next time you tilt the engine down, the gas will run out the airbox drain hole in the bottom, and be sucked into the #4 cylinder for combustion. (Be sure your airbox hose is connected to the crankcase under the bottom carb.)
