OK, so I have read all the various threads about unburnt gas/oil leaking from the prop, however my leak is 100% definitely gear oil.
Honey Mustard colored and smells of gear lube. Obviously has water in it and I have oil stains coming from the pee holes at the upper end of the LU.
I changed the LU lube last week, and changed the gear lube on 8/31 and there was no leak at that time.
Checked behind the prop and can see no monofiliment anything obvious.
What all is involved with changing out a prop seal? I am fairly mechanically inclined, but have never opened an outboard before... on a scale of 1-10 how difficult is replacing the lower unit seals, and I guess I should replace the impeller while Im in there?.
Oh, its an 85EL77S.. 1977 85 HP ..
