leaking oil.
clay1987
20220728_105948.jpgoil leaking out of the small hole. It's a 85 force. it smells like gear oil. does anyone have any ideas? It's on the lower part of the foot.
jerryjerry05
Looks like gear oil, probably leaking from one of two places???
The shift rod seal, or the drive shaft seal under the water pump.
Drain the oil, drop the lower unit, then pressure test and using soapy water find the leak.
That hole is there just for that reason, to drain excess water or unburned gas/oil from the carbs.
