I recently purchased an 8yr old Princecraft Deckboat - this is an aluminum boat. When in the water, the bilge pump kicks on about every 15 min and pumps out what seems to be gallons of water (5-10 gal maybe?).
I took the boat to the marina, where they claimed that the shift bellows needed replacement, so they replaced the bellows and shift cable.
Got the boat back, and same thing - bilge pump kicking on every 15 min or so.
Marina came out to check the boat out. Pulled the boat from the water, and noticed water streaming out of 3 holes in the keel cap. These holes seem perfectly round, approx evenly spaced along the boat and all just slightly off center - seemingly drilled intentionally. According to the marina, these holes are probably intended to ensure water doesn't get stuck and freeze and crack the keel cap. Yet - they agree we shouldn't see water stream out of the holes when taking the boat out of the water. So, they claim I have another leak somewhere. They said they would have to start tearing the boat apart to find the leak and it will get very expensive very fast as far as labor to do that. So, they claimed I may want to consider investigating the leak on my own first.
The boat has what seems to be a cooler in the floor of the boat with a drain hole that goes into the bilge area. Once we had the boat out of the water for a while and the keel cap holes stopped dripping, we poured a gallon of water into the cooler and it came out of the holes in the keel cap within a few seconds.
I have started to remove some of the floorboards (no easy task in itself) to see if we can determine where the leak is. Not really having luck finding anything - there's a lot of spray foam under there.
Any suggestions, tips on how to find the leak?
Anyone heard of holes in the keel cap?
Do note - the boat is all welded aluminum, yet the keep cap is riveted on, so I would guess the "main" aluminum of the hull is welded together underneath the keel cap. The keel cap does not seem water tight - there are gaps in the seam where it meets the "main" aluminum of the hull.
Any help would be appreciated....
