After thinking I finally got my new/used boat sorted out, I discovered an oil leak today from the prop seal. After looking at the picture closely, I noticed that the spring side of the outer seal is installed facing outwards. Aren't the springs usually facing inward?
I have receipts showing these seals were replaced 2 years ago, so not sure what's going on. I had the out drive professionally pressure tested a couple of weeks ago and they said it held 15psi for over 10 hours, and held vacuum.
I did lots of searches here and there doesn't seem to be any good step by step how to's for replacing these seals. The manual just describes full rebuild.
Boat is '03 Larson 274, outdrive is DP-SM 1.95
