Re: Leaking riser Gasket
Water will get to the cylinders because there will be water in the exhaust manifold when the engine is NOT running, but it won't get into the cylinders with the engine running.......... The exhaust will push it out.
But it is possible for valves to get rusty and stick, rings to get rusty and stick from the water that gets in the cylinders.
Be sure the manifolds and risers are in good shape. Seldom does just a gasket fail.
