Jersey Bill
- Joined
- Jun 18, 2003
- 10
I have a 89 19 ft. Sea Nymph which has some leaking rivits, some of which I believe are holding the stabilizer ribs on the bottom of the boat. Seeing as the boat weighs 1125 lbs. I am looking for solutions to fix this problem without taking the boat off the trailer and propping it up in my yard to work on it! I read some old posts here from he4givs and he had a permanent solution to it. He used aluminum welding rods with a hand held propane torch. He bought a tube of 18 rods from Weeks Dist. for 35 bucks 1-800-547-9353. Regular propane didn't get hot enough to melt the rods, He was advised to use the yellow bottle which I believe is a hotter mixture. In his post he advised they did a wonderful job. He did his whole boat and had rods left over. Also a post about 3M 5200. which they said was a good fix. I was just wondering if I could use the alum. rods while still on the trailer. (welding upside down) which I would think is very tough!. I want to fix the leaking rivits permanetly as they are a real pain in the rectum if you know what I mean. Any suggestion would be helpful, or if anyone has tried this method, please notify me. Thanks in advance.<br /><br /> Jersey Bill
