I was doing spring maintennance Sunday on the outboards changing lower gear oil. I cracked the plug on my 1978 50hp johnson and got about a quarter cup of water. I am thinking of doing the seals myself,but would like to check to see which seal is leaking. Can anyone tell me how much psi I should apply to the lower to check the seals? My intention is to drain the oil, pressurize the lower unit and put it in a tube of water. Is this the proper way to check them? I don't want to over pressurize and blow all the seals. Would the best bet be to replace input, output, and shifter seal all at the same time? Is shaft wear a issue on bad seals? I was hoping to save a few bucks on this job, since the other motors have been on a nickel and dime spree.
