I have noticed that the stator is leaking some black substance onto the timer base area. I have also noticed the volt meter stays around 14.5 to 15.0. Is this voltage too high and could this cause the leaking or is the stator just going bad. I haven't verified that the meter is accurate on the voltage reading. I recently installed a new timer base. The stator had been leaking before and has also leaked on the new timer base. I have checked the connections, everyting is good. Any info would be greatly appreciated.
