Leaks
Blueansilver
Have 2005 mercury 90 elptpo. Had new water pump put in. Went to lake. Pulled out wiping motor off. Seen discoloring on lower unit. Put boat bk in water started it. See water and exhaust coming out between lower unit and upper unit. Repair shop says that's normal. Told them u put new lower unit on wasn't discolored till u replaced water pump. Watched them drop lower unit. Said everything fine. I ask if the exhaust is leaking between housings. Then might burn up water pump. Oh no. Question is . Is it so post leak. Attaching picture
