noclutch
- Joined
- Feb 1, 2013
- 104
I recently had the 100 hr service done on my 2007 Regal 2000 @145 hrs with 5.0 GXi-J /SX-A - including outdrive removal and bearing inspection.
Prior to this my bilge has stayed dry unless water was tracked in or rained in. Since the service I had noticed an accumulation of water on two separate outings- the first time about a pint, but this last one maybe a gallon :blue:
I thought I'd read on hear somewhere about a gasket between the out-drive and transom that is not infrequently the culprit of leaking post service, but how other than by having them remove the unit again can one tell if that is the source of leakage?? Is a leak of this sort likely to cause damage to the transom by saturation? Would it be possible for it to progress to a dangerous/significant accumulation if left in the water for several days? :facepalm: I have plans for that sort of excursion next month...
I did feel some water on one of the water pump hoses at it's bottom bend ( impeller was replaced at service also) , but when I tried to twist the hose it seemed well clamped, and I don't know that water could splash up that high from bilge sloshing :cold: Could a leaky pump gasket be intermittent? (it was not obviously leaking at an idle) Could that gasket leak a gallon in 4 hours running time (some at WOT)?
Any other suggested points of water incursion or leakage I can/should look into?? And yes, the drain plug was snug and even with teflon tape on the threads....
Yea, I'm that anal....
It is running fine otherwise, with the exception that the trim position sensor is indeed water sensitive ( as I'd mentioned in another thread) as it works fine when dry but mis-calibrated when in the water, so I'm re-calibrating my head as to what the gauge actually means :facepalm:
Thanks!
Les
Thanks!
Les
