Re: leaky exhaust manifold, advice please
Dude, you would have to have one big leak to effect back pressure. The biggest problem with manifold leaks is the noise. Some engines have a big overlap in valve timing that will allow the exhaust valve to suck in cold air if there is a leak, and this can mess up the valve, but on your little toyota that isn't an issue.<br /><br />What is an issue is the aluminum cylinder head. The studs that hold the manifold on the head are steel, and the different metals combined with the extream temps causes galvanic corrosion between the stud and the head which can lead to all kinds of complications, such as twisting off the stud if the nut is frozen.<br /><br />A couple of questions, is this a 22r or a v-6? Is it the factory stock manifold o a header? The four cylinder is a lot easier to work on, and while your at it you can DX the whole EGR set-up. If the motor has a header, figure leaks are just part of life. I have never seen a header that didn't leaks occasionally because they just not a strong as cast iron and warp over time.
