leaky seals
handle
Replaced both hubs #1250 with new bearings and seals, I still have grease coming out the back seals. Is there anything that can be done to the worn spindle to stop grease from leaking out without having to replace the axle?
robert graham
Re: leaky seals
There's some stainless steel sleeves that fit over the spindle seal surface to sorta smooth out and build up a warn surface...trailer supply places should have them...Good Luck!
handle
Re: leaky seals
I called SKF (Vehicle Service Market) the website you suggested, they told me they did not make a sleeve product for trailer applications.
handle
Re: leaky seals
Bruce thanks for your input, looks like the fix I was looking for.
