leaky seam on tracker deck boat
fisherglenn
Hi, I have a 1999 Aluminum Tracker Party Deck 21, which is leaking along the bottom seam. Anyone recommend a good epoxy, or other solution for the problem?
mattdd
Re: leaky seam on tracker deck boat
i used a 3m marine epoxy in a caulk tube. forget the name but its a wite tube with purple 3m logo. it has been working great for 3 years now. wire wheeled the seam first, ran a bead down the seam and repainted. went from major leaking to dry as a bone.
1730V
The 3M product is: 3M-4200.
If you can get to the seam from the back side (inside), use Gluv It.
Both products are available, here on iboats.
Ayuh,.............. Gluv-it is a Tin Boater's Best Friend.................;)
