Lean/ Rich knob on 73,18 evenrude
herothc2003
The low,high speed ,lean/rich knob on a 73 18hp evevenrude, when do I need to adjust it, and what is it for? :confused:
Joe Reeves
Re: Lean/ Rich knob on 73,18 evenrude
That slow speed needle valve controls the flow of fuel to be mixed with air at the lower rpm range.<br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br />(J. Reeves)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /> <br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /> <br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /> <br />Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.<br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway
