MajBach
- Joined
- Jun 21, 2003
- 564
Preamble: 2002 Maxum 2300 SC w/ Merc 305 Alpha I Gen II with less than 300 hrs. It's also equipped with that heat transfer thingy for salt water.
Hi, Fellas! So here is my situation. Last year was my first season with the boat above (2nd owner). It has low hours and I also had the dealer in Seattle give it a thorough tune up etc before I took delivery. They changed the impeller and steering pump, plugs and rotor and whatever else.
My first season with it (and an I/O) and there were not too many surprises. It kicks out a little smoke when I start it after its sat for a month and Ive noticed a reoccurring squeak about 50% of the time that is clearly connected to the serpentine belt that disappears once the engine is warm. My trim gauge also went U/S but Ive determined the part and procedure to fix it and deemed it unnecessary to replace until something else in that area needs remedying. Ive also purchased a full shop manual.
My reason for writing today is because I still feel very ?green? as to knowing and understanding this power train and applying timely preventative maintenance etc. The boat is stored indoors and always out of the water and there is sufficient room for me to work on it when required, however, ?our time together? is quite limited due to how far I am away from it so I need to go in ?prepared? as it were. Despite being a ?do-it-yourselfer?, even changing the oil on it for the first time will require me to do my homework ahead of time. And, Im paranoid about ?the risers?. Despite low hours, the boat is over a decade old and I am concerned about ensuring their operational condition.
So, I?m looking for some Spring check list type stuff here (and cant seem to find it). I did find the ?summerizing your winterized boat? but am hoping for something more. Another member also posted regarding his issues with manifold risers but his was a different engine than mine so I don?t know if the replies he obtained apply to me.
Anything helps, guys. From Step A to Z for what I need to change the oil, to torque settings for head bolts and gasket part numbers so that when I drive out there next week, I will have proper tools, parts and knowledge in hand, and, er?head.
Thanks a heap in advance.
