led lights on your fishing boat?
boatman1971
008.jpgim wanting to install some led lights for nite fishing.has anyone done this im trying to get an idea as far as location and what types of lights will work best.
MH Hawker
Re: led lights on your fishing boat?
Their several ways you can go with type and location, I added a few in key areas in red, red wont mess you your night vision ever other color will.
edit: and yes any extra lights need to be contained in the boat so as not to be confused with nav lights. I am using a pontoon boat so ever thing is inside of the fence.
dingbat
My cockpit lighting is under the gunnels facing down. Throws light only the floor.
Red is good for night vision, but I don't see the point of installing red lighting to fish since your required to have your all around lights on at all times at night.
I have red lights in my overhead light at the helm and in my instrument panel. My hardtop blocks the light from the all-round light from my field of vision at the helm.
Splat
Red isn't as effective at maintaining night vision as many think. Plus most people install red lights that are too bright, they do more harm than good. A very low level blue green, with just enough red to eliminate the blind spot is way more effective at preserving night vision, while also allowing you to see details such as chart numbers, gauges, and fishing knots, and allowing you to keep your peripheral vision photoscopic.
A very dim white light works equally well. But has to be dim. If you can see colors, it's too bright and effecting your night vision.
Red lighting can also confuse other traffic on the water as to your current direction of travel. I used to use red until I had a fellow at the dock approach me one night and tell me it was hard to determine my direction of travel.
I would recommend blue or amber. Low level Blue being the preference. If you search amazon for waterproof led strip light, you can get a roll of the color of your choice for about $16. I would also recommend a roll of double sided 3M trim tape to secure them. They come with a sticky back, but the adhesive is sub par in my opinion and comes loose after a short time.
Bill
boatman1971
thanks guys,im looking for something to light the boat up so we can see our rods.and the boat iself so were not tripping over stuff.i saw the flush mont leds on iboat i wasnt sure if it would be too bright though.
