Re: leg #'s
I'm not completely positive about this, But I believe it has something to do with the newer emissions standards for the engines.
do you know why or what they changed to bring the max wot to 5200 that they now spec
You are correct, They did raise the WOT on this engine to 4800?5200 and they also lowered the idle RPM's down to 550 rpm on most of the newer MPI engines.
RPM WOT 4800?5200
Rev limiter 5350
Idle in neutral 550
Merc's web site has it as 5200 so I guess what I'm really asking is 2007/2008 4600/5000 or 4800/5200 as per the web site this is a new unit to me and I dont want to damage it. but will I be over reving.? PS I'm also aware that the rev limiter is or should be + 200 rpm over max wot
Since you have a rev limiter you will not be able to over rev the engine. The limiter will stop you at 5350 RPM and when you hit the rev limiter it will sound and feel pretty much like a engine misfire.
Try to find a prop that will put in the 5150 area at WOT while trimmed out, You should be good there.
If your not getting close to your top rpm range right now then you should check to see if your getting full wide open throttle at the throttle body due to a misadjusted throttle cable.
I see your engine is a 350 MPI bravo sea core with a bravo 2 sea core drive? Nice setup you have there.
