It appears to me that a previous owner has shortened the tongue on my boat trailer. I think it could use a bit more length.
The usual tongue metal tubing seems to have walls about an 1/8" thick.
I just happen to have a chunk of steel the right size but it is 1/4" thick.
Can any of you folks think of any reason why using the heavier steel should pose any problem apart from adding some weight to the trailer?
I suppose it would be less likely to crumple in a crash but that might be the least of my worries if hit from behind hard enough to need the tongue to collapse.
The trailer is an old tandem axle unit and the boat is a 20' aluminum I/O.
