Strychn9ne
- Joined
- Aug 27, 2016
- 34
I took my '65 Starcraft out the other day, everything was going well until I noticed it was moving slower and was hearing a squealing sound from the engine ('65 Merc 350 35 HP) suddenly. We went back to the landing and pulled it out of the water right away and I noticed the prop was wearing into the lower unit! Took the prop off and found an old style brass thrust washer with no splines in it had been installed on there from the previous owner without the required splined backing washer. The thrust washer had worn into the bearing carrier, and the prop into the lower unit. I originally thought the hub was slipping as the damage is hard to see until you look closer, but it now appears that was not my issue:facepalm:. So, lesson hard learned! Check everything out before using a used boat!!! Luckily I don't see any metal filings in the gear oil and only minimal water came out. I only had it out for about 1.5 hours total. The previous owner had obviously not used it at all or that would have happened to him. The prop shaft still turns freely, so I think I escaped internal damage.
Anyways, I have already began buying parts for a lower unit case swap. I found an NOS bearing carrier assembly (I think it has bearings in it already too), gear case from a Merc 500 (Same part number as the Merc 350 case), carrier lock nut thing, seals, and the correct updated thrust washers. I think I have everything needed for the swap. Again I got lucky and found the gear case on Ebay for $90 shipped and in really good shape.
So I'm curious, how hard a job is this? I've never had a lower unit apart before, but I am mechanically inclined and work on cars and other small air cooled engines sometimes. I know I'm gonna need a service manual, but I'm just wondering if this is a job better left to a boat mechanic or if it's worth doing it myself. How much would a typical shop charge for swapping my parts into the new case? I have all the major parts of course, so I'm guessing it's mostly going to be labor charges and a few small odds and ends I may be missing.
