Lets see who is the quickest... easy one
doug9238
I have to change my trim/tilt unit on my 1978 Johsnon 85HP. Does anyone know what size socket I need to take off the large nut that is on the bottom of the steering arm assembly. The part number for the nut is 0320746
Thanks!!!
bktheking
Re: Lets see who is the quickest... easy one
Another site says 1 1/16" but the guy was hazarding a guess.....a set of digital calipers will tell you for sure!
doug9238
Its got to be bigger than that. I tried my trailer hitch ball wrench on it, and it is even a little too small. I was hoping to find out before I go home, so I could borrow the correct size socket from work before I leave today.
I checked the parts manual, but the description does not include the nut size.
bktheking
Measure it, tape measure, calipers are best.
doug9238
Thats what I will do tonight, but I am hoping to get an answer today. That way I won't have to go back to work again later to get the correct size socket. Anyone else know the answer?
Rscardina
1 3/4 inches.... just did mine a month ago!!
doug9238
Thank you sir. You saved me an extra trip across town!
Rscardina
Yeah she is a big one... hopefully you sprayed a little something on it before hand...
I had to do engine mounts on my 140.. I needed to apply a tad bit of heat to pop the rust flakes off...she came off easy..
good luck!
