I am trying to put the tilt cylinders from my force outboard on this old thing that doesnt have t+t. Should be easy enough since it has the same mounting for the pump. I will not be able to use the trim (wont fit) so I will cap off the lines ging to it so that only the tilt operates. My problem is that the pin that goes through the top of the struts has no sort of nut or anything holding it. I tapped it a couple times with a hammer and it didnt move. How does it come out? I dont want to hit it harder and risk breaking something unless thats how it is supposed to come out.
