I need to lift my 1978 175 HP 'rude. Try as I might, I can not find any lifting eye on the motor. I want to screw a lifting eye onto the flywheel bolt and pull stright up. The only lifting eyes I can find a flywheel puller that screws into the three holes on the flywheel. Instead of the puller bolt, a ring is screwed into the center.
Will this work?
Is this the only option available?
Where can I find the proper ring?
Thanks,
Learn2Dive
Will this work?
Thanks,
Learn2Dive
