Re: Lifting the motor with the fly wheel
but I don't know the screw size for the three screws or the thread count on them.
hello,
most early engines will be SAE threads. i am not sure if any metric showed up in later years like in auto industry. if it were mine, i'd:
a) call a marine dealer, ask for service and ask for thread size. they may tell you.
b) i suspect it most likely is 5/16ths course. or close if metric. i doubt it is 3/8 x 18. [course] but it may be.
c) i would also consider going to hardware store. get one size of each. 5/16ths and 3/8s. and metric same size appros. then just thread it in and return what u dont need and get others so fixture will bolt up. before u go to hardware get up close to threaded hole and ck to see if course or fine.
i assume u have no boltsBox? i have a washerBox, nutBox, boltBox, etc. if so, just fit til it goes in.
you may not have a tap n die set, but if it wher mine, id first chase the threads, and then a drop or two of oil on bolt.
let us know what thread it is if u pull it by flywheel.
good luck,
regards
lakester
