Re: Lightening Attraction
Here's a follow-up question, b/c I don't know: If you are in the middle of a body of water in a big old honkin mass of aluminum and stainless steel, isn't the lightning going to hit you regardless of an extra 5' of height? IOW a bolt coming from 2000 feet would read your 10' superstructure as well as 10' + 5', right?
Yes it is going to see you as the shortest path reg of the extra 5~8' antenna but minimizing height would seem to me a good idea. Not to mention the collapsible mount will keep you from whacking low limbs and overpasses on your way to and from.
Now I can see grounding for reasons in any circumstance, but the specific question concerned the added antenna.
ALso, on a fiberglass boat, should you run a braided ground back to the motor? Off the transom on a dedicated ground?
thanks
For current supply and safety reasons, radio power wires both positive and negative should be run directly to the power source and fused close to the battery.
Braided is not required but my preferred for the antenna ground It provides a DC ground as well as a good RF ground. It should be attached to as much metal as possible. The engine is a good choice on a FG boat. If it has any chances of diverting a strike hopefully it will go through the out drive, prop shaft, ect..
I'm not sure about putting grounding plates on the hull? Talk about throwing a monkey wrench into hydrodynamics. I guess it would be Ok on a displacement hull where planing and friction weren't a major concern.
I don't see a FG boat as being seen by lightning as having alot of "Ground Potential". So actually I think a FG hull would be less likely to attract thus safer. But like I posted before. Lightning hasn't read any books and will do whatever it wants.
I've been an Amateur Radio Operator for 30+ years
These are just my opinions and methods. I am sure there are others out there that work as well or better.
I'm of the opinion that nothing is 100% when discussing lightning and the protection from. If it hits you and you and your stuff survives you got lucky. Next time it may cook your noodle.
Be Careful & Happy Boating.
