Lightning and no thunder
Limited-Time
I know I could just Google this but does any one know the distance thunder travels before the sound dies out. I sat on back deck last night a watched a lightning show and never heard any thunder.
ezmobee
Re: Lightning and no thunder
Drove through a thunderstorm on the way home from vacation on Friday night with WICKED lightning and I kept expecting real loud thunder and heard none. It was weird.
SS MAYFLOAT
LT, around here, we call that heat lightning. It is lightning that jumps from cloud to cloud vs from the clouds to the ground. From what I have learned, the boom from thunder is actually the electrically charged bolt shooting through the air so fast it is breaking the sound barrier.
Limited-Time
It was cloud to cloud, but you could clearly see the jagged streaks/bolts of lightning. The same type of bolts you see hitting the ground. As for the sound it's my understanding the lightning's heat causes a rapid expansion of the surrounding air. This expansion creates a "sonic" air wave which is the sound we call thunder. So I can't see it mattering whether the lightning hits the ground or stays in the air............... it should still make the sound. Or is this like the tree falling in the forest??????
drrpm
It is like the tree falling in the forest. It makes a sound but you're too far away to hear it. I believe that if you see lightening but hear no thunder its at least 10 miles away.
I always thought that was from lightning that never touched down, and the thunder was the sound of it hitting ground.
rbh
Heard something about the sound thunder makes, if it goes boom it going away from you if it goes crack its coming towards you, something about the dopler effect????
CheapboatKev
Once you see the flash of lighting..
Start counting in seconds..
Each second = 0.217 of a mile
10 second count will equal 2.17 miles away
something about the speed of sound being @ 1,150 fps
